seems to be too big and the WG pipe is in the way...what have other people done?
Edited by Gainzy
Here's a shite drawing
The two here bits is where the lambda sensor can go but the screamer pipe is in the way of both I will either have to bend the lambda
Sensor or find a shorter one it won't screw straight even with the screamer not attatched to the gearbox :(
Mine needed a slight bend put in the lambda to clear the ewg pipe....
How did you bend it? Thanks for the comments
  • 2 weeks later...
