Djaniero Posted June 18, 2014 Share Posted June 18, 2014 (edited) I did a search, but couldn't find exactly what I was looking for. Can you guys gimme some input on which rad to use for my td04 setup? My toyosports mani will supposedly clear my stock rad....but it will be pretty tight? So I was thinking to get a civic half size rad instead.My car is never going to be on track, so would a normal vti none alloy rad suffice, or would I need a twin core/triple core rad? Failing that, I was considering a swift gti rad, as the bottom rad outlet is on the exact same side as the stock starbo rad (the civic rad outlet is on the opposite side so the rad pipe is quite close to the mani) Thanks Edited June 18, 2014 by Djaniero Quote Link to post Share on other sites
Cushion Posted June 20, 2014 Share Posted June 20, 2014 Im running a single core rad with a td04 setup at 1 bar. Never ran it on a track but the temp needle has never gone past half way which is where it used to sit with the standard rad. Bought it brand new of ebay a couple of years back for £30 delivered and since ive never had any issues with it ive never got round to buying a double core Quote Link to post Share on other sites
Djaniero Posted June 20, 2014 Author Share Posted June 20, 2014 Got any pics of it fitted ? Also what fan are you using? Thanks Quote Link to post Share on other sites
Bussey Posted June 20, 2014 Share Posted June 20, 2014 When I had a toyo sports on my td04 setup, there was loads of room between the rad and the turbo, plus cooling was bang on even when being driven hard Quote Link to post Share on other sites
Cushion Posted June 20, 2014 Share Posted June 20, 2014 Fan off the standard rad mate. Cant get pics atm bud but ill try later on Quote Link to post Share on other sites
Djaniero Posted June 20, 2014 Author Share Posted June 20, 2014 When I had a toyo sports on my td04 setup, there was loads of room between the rad and the turbo, plus cooling was bang on even when being driven hard hmmm a couple of people have said that already....maybe I'm best off saving my money then. If its not broke don't fix it. Only thing is...mine has been modded slightly and now runs an ex wg Fan off the standard rad mate. Cant get pics atm bud but ill try later on Thanks man Quote Link to post Share on other sites
Bussey Posted June 20, 2014 Share Posted June 20, 2014 If put the money towards another manifold to be honest haha, toyos crack so quickly Quote Link to post Share on other sites
Djaniero Posted June 20, 2014 Author Share Posted June 20, 2014 I'm gonna try my luck...already been braced to fuck Quote Link to post Share on other sites
AlancEP82 Posted June 20, 2014 Share Posted June 20, 2014 Been running a ss TD/ vf series toyo mani for about 3 years now never crack or brace never welded either I must be lucky lol Quote Link to post Share on other sites
