TD04HYBRID Posted June 19, 2014 Share Posted June 19, 2014 Hi guys/girlsI have my mapping session tomorrow after a lot of hard work took it for a drive tonight after going externally gated and getting really bad boost creep I'm running on a hks evc 6 boost controller and a turbo smart waste gate!Why would I be boost creeping from set on 7.5psi until mapped to 16psi? Have I put the vacuum on wrong? Quote Link to post Share on other sites
jayc-glanza17 Posted June 19, 2014 Share Posted June 19, 2014 (edited) what wastegate spring you running? PSI wise Edited June 19, 2014 by jayc-glanza17 Quote Link to post Share on other sites
TD04HYBRID Posted June 19, 2014 Author Share Posted June 19, 2014 Hi mate I'm not too sure think it's .8 bar told Keith my plans to run 1.8 so he supplied everything I needed? Quote Link to post Share on other sites
jayc-glanza17 Posted June 19, 2014 Share Posted June 19, 2014 maybe the gain on the boost controller is set too high. does it come in too high and level off higher up revs? Quote Link to post Share on other sites
TD04HYBRID Posted June 19, 2014 Author Share Posted June 19, 2014 The boost controller is set from previous before I went externally gated and I would only get a creep of 2psi if that?As soon as I saw the creep I let off due to it's only had it's base map would that have something to do with it? Will it be fine after a map Quote Link to post Share on other sites
daniel_g Posted June 19, 2014 Share Posted June 19, 2014 EBCs normally have different settings for internal & external wastegates.You might just have to let the mapper set it up because you cant really do big long pulls to set it yourself if its not properly mapped yet. Quote Link to post Share on other sites
TD04HYBRID Posted June 19, 2014 Author Share Posted June 19, 2014 Cheers for the comments guys I thought it may be the case to leave it to the professionals lol! Quote Link to post Share on other sites
jayc-glanza17 Posted June 19, 2014 Share Posted June 19, 2014 if its just coming in and then levelling off, then its easy once mapped.. mine creeps on initial spool, but once wastegate opens holds boost fine.. let the tuner see it first when mapping mate. good luck for tomorrow, a week till im mapped. Quote Link to post Share on other sites
TD04HYBRID Posted June 19, 2014 Author Share Posted June 19, 2014 if its just coming in and then levelling off, then its easy once mapped..mine creeps on initial spool, but once wastegate opens holds boost fine..let the tuner see it first when mapping mate.good luck for tomorrow, a week till im mapped.Thanks Jay! Done too much to this so quite scared tbh that won't make as much lol! Love your build fella Quote Link to post Share on other sites
_shaun_ Posted June 20, 2014 Share Posted June 20, 2014 Just pull the vacs of the ebc and set it running to wastegate pressure to rule out it being something todo with wastegate Quote Link to post Share on other sites
GP82 Posted June 20, 2014 Share Posted June 20, 2014 The HKS EVC does have setting options for internal and external wastegate setups! If the engine is not mapped I would do as said above, turn boost controller off and jus' run off the wastegate spring pressure if it's safe to do so. Quote Link to post Share on other sites
TD04HYBRID Posted June 20, 2014 Author Share Posted June 20, 2014 Cheers guys spoke to my mapper and he said it's fine just drive off boost! Leaving in a hour for the big day Quote Link to post Share on other sites
