Rear anti roll bar kit
The end links where alfa romeo links, they are quite thick so where cut, extended and welded back. There are longer links about that you could use but youd have to look into it. The bushing brackets are the ones of the transit and u clamps over the axle bolted through the brackets.
Gent! Cheers for the info
