Strange thing is happening when i am accelerating:
- 2nd gear / ~40 km/h
- then full acceleration
- boost gauge is showing steady 0.65 bar (not rising)
- ... suddenly ~0.9 bar and fuel cut
This "overboost" is not happening everytime.
Do anybody have idea why it can happen?
Where should i look for the reason of this situation?
Westgate or actuator is jamming??
Any suggestions will be appreciated.
Car spec (EP82 with 4E-FTE):
- standard CT9
- standard fuel pressure
- exhaust 2.5" with end muffler
- standard TMIC + standard DV (as blow off now)
- Apexi air filter mounted in front of the radiator
- EBC => MAC valve + piggyback DET3
Piggyback is controlling boost level (0.65 bar) and spark advance (up to 5 additional deg in highest rev).
It is not changing signal from ori MAP sensor.
I have always had manual boost controllers with no issue at all
bought a brand new gizzmo for 200 quid and it kept overboosting, has put me off ever having another ebc.
im sticking with manual boost controllers now, I tryed all the different settings on that ebc and it was fucking wack.waste of money.
worst bit was I cant sell it as its useless.
Theoretically ebc solenoid is new ... but who knows. I still have few months of warranty.
If i will have time, i will connect additional MAP sensor to vacum line that powers the actuator and check what is the pressure there while i have that overboost.
If i wont have time, i will just make a claim and let "them" to check it (or most probably change to new one).
thx
I still have my MBC but for me it was pain in the ...
I was not able to have the right setup for cold and warm weather, boost spike after gear drop was occurring, etc (planned boost level ~0.8 bar).
Thats why i have "invested" and bought EBC solenoid. It wasn't so expensive upgrade (~60 Euro), because my piggyback has 2 power outputs (up to 5A).
It would be a big waste if i wouldn't use those. I made simple map for it (work of solenoid depends from boost pressure and revs) and it is working ... almost perfectly ;)
