DRiiFTiE Posted June 26, 2014 Share Posted June 26, 2014 Hi guys quick question! Whats a good reading for compression test in engine? and whats a low reading and bad sign.. Cheers Quote Link to post Share on other sites
Eynonz Posted June 26, 2014 Share Posted June 26, 2014 I asked this a while back and I was told that it should be 160 across all 4 for a healthy result. Quote Link to post Share on other sites
DRiiFTiE Posted June 26, 2014 Author Share Posted June 26, 2014 I asked this a while back and I was told that it should be 160 across all 4 for a healthy result. Mines reading 180 on all 3 and last 1 (4) 185 so shes okay id say! Quote Link to post Share on other sites
H_D Posted June 27, 2014 Share Posted June 27, 2014 Mines reading 180 on all 3 and last 1 (4) 185 so shes okay id say! I think that is a bit high tbh should be in the region of 150 - 170 max. Quote Link to post Share on other sites
DRiiFTiE Posted June 27, 2014 Author Share Posted June 27, 2014 I think that is a bit high tbh should be in the region of 150 - 170 max. Okay, it doesnt matter too much anyway bud.. the engine is coming out weekend to be forged so ! Thanks anyway Quote Link to post Share on other sites
H_D Posted June 27, 2014 Share Posted June 27, 2014 The cause of the high compression will more than likely be due the head being skimmed to much in the past.When forging go for a 1.6mm or 1.9mm head gasket to bring the compression back down. Quote Link to post Share on other sites
DRiiFTiE Posted June 27, 2014 Author Share Posted June 27, 2014 The cause of the high compression will more than likely be due the head being skimmed to much in the past. When forging go for a 1.6mm or 1.9mm head gasket to bring the compression back down. sweet budday! know any ep91 or 82 forsale? Quote Link to post Share on other sites
H_D Posted June 27, 2014 Share Posted June 27, 2014 Selling my ep82 after 22/07/2014 as mot is due on that date. Quote Link to post Share on other sites
DRiiFTiE Posted June 27, 2014 Author Share Posted June 27, 2014 Selling my ep82 after 22/07/2014 as mot is due on that date. pm photo? Quote Link to post Share on other sites
scottieboi94 Posted June 27, 2014 Share Posted June 27, 2014 Mine ran 170 through all cylinders Quote Link to post Share on other sites
H_D Posted June 27, 2014 Share Posted June 27, 2014 http://www.ukstarletowners.com/topic/74076-newish-daily-ep82-more-pics-6614-selling-up-soon/ Quote Link to post Share on other sites
AdamB Posted June 28, 2014 Share Posted June 28, 2014 Anything below 140psi requires a rebuild ideally. Providing results for each cylinder are within 1 bar or 14.5 psi of each other then it's fine. I personally wouldn't be using anything more than a 1.2mm headgasket on these engines, compression is already too low as it is imo. Quote Link to post Share on other sites
