Hey guys
As a few know I have a broken GT
I have bought a low millage non modded bottom end and plan to use my head.
Now I think I know my full list but please let me know if I am missing anything
Head gasket
Head bolts
Cambelt
Water pump
Oil pump
Headgasket
Stem seals
Crank shaft seal (I think)
Inlet gaskets
Manifold/turbo gaskets
Anything else I will need?
I plan to renew these items while I am at it.
Fuel filter
Fuel line
Turbo oil/water feed
Ht leads
Dizzy
Coilpack
Starter
Alternator
Anything else?
Should I do pistons rings and get items skimmed while I am at it.
Thanks
Alex
When I rebuilt an engine from a bare block I used the following.
- full toyota gasket set
- full acl bearing set
- water pump
- oil pump
- piston rings
- head skimmed and block checked (block didn't need decking)
- bores cross hatch honed
- cambelt kit
- had the block/head acid dipped and washed (would recommend that to get rid of sludge and shit in the oil/water ways)
- new coolant hose kit as mine was looking old and didn't want hoses splitting
- new plugs/dizzy
Wasn't cheap!!!! And then had to take her for another remap once the fresh engine was bedded in. The things we do all for a 1.3 hahaha enjoy.
