Ollieh17 Posted July 1, 2014 Posted July 1, 2014 (edited) Seeing if theres any second hand before i order one from zisco Edited July 2, 2014 by Ollieh17
daniel_g Posted July 1, 2014 Posted July 1, 2014 As far as im aware the Zisco harness is an extender and the EMB still needs wired into this, just means you arent hacking into the loom is all. I doesnt actually make an EBM plug and play into your ECU / loom.Please correct me if im wrong lol.Or ignore if you already know this haha.
Ollieh17 Posted July 1, 2014 Author Posted July 1, 2014 You you are correct. Plug and play harnesses seem very hard to come by!
triple j Posted July 2, 2014 Posted July 2, 2014 U could make one like i did have a lookhttp://www.toyotaownersclub-irl.com/t57800-diy-ep82-boomslang-harness?highlight=boomslang
Ollieh17 Posted July 2, 2014 Author Posted July 2, 2014 U could make one like i did have a lookhttp://www.toyotaownersclub-irl.com/t57800-diy-ep82-boomslang-harness?highlight=boomslang i did consider this, but would be hard to come across the three plugs for a glanza ecu, without someone wanting to cut there loom
triple j Posted July 2, 2014 Posted July 2, 2014 Hit the scrap yard there should be some 4efe about, also cut an extra one out u may need to add a few extra pins for 4efte.
Ollieh17 Posted July 2, 2014 Author Posted July 2, 2014 Hit the scrap yard there should be some 4efe about, also cut an extra one out u may need to add a few extra pins for 4efte. Don't the 4efe ep91s only have a two pin ecu?
Ollieh17 Posted July 2, 2014 Author Posted July 2, 2014 would also consider making my own. So if anyone has a old glanza ecu that i can use the rear plug from, ecu doesnt have to work just the plug in good condition. Also the three plugs off a glanza loom, literally just cut off if someone has a loom that is scrap
