Hi guys, ive rotated my tf035 90 degrees. could you tell me if it looks right and which one is the oil return? I thought the oil return was the straight pipe sticking out but this would face towards the engine instead of downwards?
help appreciated thanks
its just a guide, as the turbo rotation generally needs tweaking to match the specific set up
once you have the turbo in a state where both the compressor and turbine side are able to rotate, then its best to place it on the car and make the final adjustments before tightening/clipping everything up
