Turbo Goose Posted July 3, 2014 Share Posted July 3, 2014 Hi guys, ive rotated my tf035 90 degrees. could you tell me if it looks right and which one is the oil return? I thought the oil return was the straight pipe sticking out but this would face towards the engine instead of downwards? help appreciated thanks Quote Link to post Share on other sites
Socks Posted July 3, 2014 Share Posted July 3, 2014 Oil return is the pipe at the bottom of the 3rd pic... That needs to point straight downward... Quote Link to post Share on other sites
5e colin Posted July 3, 2014 Share Posted July 3, 2014 you only rotated the comp housing !!!! you nead to rotate the CORE so the strait pipe ( oil return ) faces down then align the comp housing ( silver ) Quote Link to post Share on other sites
Turbo Goose Posted July 3, 2014 Author Share Posted July 3, 2014 so once the clamp is off, i remove the exhaust housing. then how to i rotate the core?thanks Quote Link to post Share on other sites
Turbo Goose Posted July 3, 2014 Author Share Posted July 3, 2014 http://www.toyotagtturbo.com/forums/showthread.php?11001-Steps-On-How-To-Rotate-A-Tdo4l-Turbo i followed this guide which is obvs bull as the oil return is facing the wrong way on this one Quote Link to post Share on other sites
gorganl2000 Posted July 4, 2014 Share Posted July 4, 2014 its just a guide, as the turbo rotation generally needs tweaking to match the specific set up once you have the turbo in a state where both the compressor and turbine side are able to rotate, then its best to place it on the car and make the final adjustments before tightening/clipping everything up Quote Link to post Share on other sites
