Braided Drum Brake lines
Contact HEL, they will make you a pair up for the rear ( you don't need to send them old lines), I have them going from the chassis of the car to the axel. Explain to them in a email that you just need a double ended line with fittings for attaching onto hard lines, I'm sure they will understand... say it's for a ep91 drum brakes too.
I will get a photo if it's not chucking it down tomorrow :)
Edited by Jamie5414
spot on bud, be great if you could.
Seems custom lines are the way forward, must nab some from the scrappies to save any down time
We don't do that kit currently, but as you say we could supply braided versions of any lines you send us?
Thanks, like mentioned above, need to try get some spares to avoid any down time
