ashley newbert Posted July 7, 2014 Posted July 7, 2014 I don't want to put a glanza engine in my car, I want to turbo my engine, what things do I need to turbo my car, obviously I need a turbo but what ecu other electrical bits do I need, could someone please help me ... Quote
richardc9052 Posted July 7, 2014 Posted July 7, 2014 sump, strainer, oil filter housing, thermostat housing, mani, turbo, water and oil lines, exhaust modifying or replaced with a glanza v one, intercooler setup, 4efte injectors and a piggyback + map. OR use a full glanza loom and ecu using all glanza sensors etc Quote
ashley newbert Posted July 8, 2014 Author Posted July 8, 2014 but if i use the glanza loon, dont i have to change the clocks and all the instuments in the car??would corolla injectors work??which piggy back ecu could i use and which map sensor, do you know of any ?? cheers pal Quote
Ollieh17 Posted July 8, 2014 Posted July 8, 2014 This has been covered loads of times mate. Use the search Quote
richardc9052 Posted July 8, 2014 Posted July 8, 2014 Do the above and use a piggyback. Much better than swapping loom. Use an aem fic6 they are made for turbo'ing na's Quote
ashley newbert Posted July 18, 2014 Author Posted July 18, 2014 when you say the oil filter housing do i just need the sandwich plate ??same with the thermostat housing whats the difference?my engine currenty has the corrola injectors could they do or do i need the 4efte injectors ?? cheers mate Quote
morgey Posted July 18, 2014 Posted July 18, 2014 Oil filter housing has oil feeds on it. Thermo housing has water outlets.Id get fte injectors just to be safe Quote
ashley newbert Posted July 18, 2014 Author Posted July 18, 2014 so all i need is the glanza housings for the oil filter housing and the thermostat housing?? cheers for the input pal appreciate it Quote
