Chand Posted July 13, 2014 Posted July 13, 2014 After the 3 bar map sensor that works with a power fc and loom if possible Long shot I know but didn't want to wait 3 weeks to get one from America Thanks Chand
abbott Posted July 13, 2014 Posted July 13, 2014 Very hard to get one chap your best bet is to use a gt4 or st205 map sensor best to join forum and put a wanted up. They are getting harder to find also. Theres a guy on ebay who does the apexi one and think you would get it within a week
Chand Posted July 13, 2014 Author Posted July 13, 2014 Yeah that's what I've been looking at is the the st205 import turbo celica turbo map sensor can run 25psi so like 1.7bar ish You run power fc?
H_D Posted July 14, 2014 Posted July 14, 2014 (edited) I have a 2.8 bar map sensor for sale - it came of a celica GT4 its a straight plug n play so no messing around just needs to be scaled down by the mapper.PM if interested. can be ran upto 1.8 bar.IIRC socks ran the same map sensor when he was on a power FC Edited July 14, 2014 by H_D
Socks Posted July 14, 2014 Posted July 14, 2014 2.8 bar map sensor (1.8bar of boost) is what I used... However, the other option is the GM Sensor... http://www.ebay.co.uk/itm/Genuine-Proper-GM-3-Bar-Map-Boost-Sensor-Wiring-Plug-Apexi-Power-FC-Motec-/131232497406?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1e8e10fefe I very nearly used one of those... Tried and Tested to work with the PFC... Altho saying that if your on PFC, you'll hit the limit of the ignition system at 1.7-1.8bar anyway... If your on a fairly large bine...
