*GlanzaTurboV* Posted July 14, 2014 Share Posted July 14, 2014 How do I tell the difference between an oem box and standard?Cheers Quote Link to post Share on other sites
5e colin Posted July 14, 2014 Share Posted July 14, 2014 simple climb under the car and check the drivers side drive if its bolted to a metal lump sticking out of the box then your lsd look in this link thats a oem lsd box http://www.toyotagtturbo.com/forums/showthread.php?51387-NEED-HELP-IDENTIFYING-THIS-GEARBOX-(pics-inside) Quote Link to post Share on other sites
maddox710 Posted July 14, 2014 Share Posted July 14, 2014 Here's my way http://www.ukstarletowners.com/topic/79993-how-to-tell-if-your-gearbox-has-lsd-or-not/ Quote Link to post Share on other sites
*GlanzaTurboV* Posted July 14, 2014 Author Share Posted July 14, 2014 Ahh right pretty easy way of telling then is an oem LSD as good as a Cusco or qualify? If not how far off..Cheers Quote Link to post Share on other sites
5e colin Posted July 14, 2014 Share Posted July 14, 2014 hard to compare really the gear ratios are diferent but i think aftermarked are better for sure ( they will be stronger ) mine sometimes acts like a non lsd when over taking when touching the wite lines on the road of she gose then far right !!! ( flat out overtake ) Quote Link to post Share on other sites
