M7WSY Posted July 16, 2014 Posted July 16, 2014 Any guides out there? I'm brand new to the forum and trying to get my car to be fully boosting by 3/3.5k, it's running a ct9 hybrid set up but not getting full boost 17-18 psi untill about 5k,also looking for a idiots guide to actuators? Thanks in advance Quote
5e colin Posted July 16, 2014 Posted July 16, 2014 wel this deffo aint supposed to be your 1st post theres the so caled newbie section !!!!! Quote
Socks Posted July 16, 2014 Posted July 16, 2014 Ok! Actuator is easy to setup. You want to set it so its not so loose it vibrates and doesn't close the wastegate port. But not so much tension it'll overboost. Generally. It was to be just enough tension to hold the port shut... Then the boost controller increases from there.. Increase the Duty Cycle 5% at a time, doing 3rd or 4th gear pulls. Until you hit your desired boost level (or fuel cut, then back it down until it doesn't hit fuel cut at all) Once that's done. Increase the GAIN. 5% at a time, until the boost doesn't spool any faster... The Gain should never be higher % then the duty... Simple Really Quote
M7WSY Posted July 16, 2014 Author Posted July 16, 2014 I haven't got a clue about the actuator I'm not going to lie,I can't even find the bloody thing,it's nowhere near the turbo! And I have an external waste gate on the screamer pipe,for the boost controller it's more what goes where,I know how to set it up once it's all wired in but I have no idea how to wire it in 😂 Quote
Ollieh17 Posted July 16, 2014 Posted July 16, 2014 You won't have a actuator with a external wastegate Quote
5e colin Posted July 16, 2014 Posted July 16, 2014 (edited) Thanks for the warm welcome no bother ha ha its more like when you give an introduction of your selves and what your ride is more members will answer your questions !!! welcome Edited July 16, 2014 by 5e colin Quote
M7WSY Posted July 16, 2014 Author Posted July 16, 2014 I would have done a formal introduction however my head is pickled with this bloody car!😂 Quote
M7WSY Posted July 16, 2014 Author Posted July 16, 2014 So how the hell do I get the thing to spool up quicker?apart from boost controller? Quote
M7WSY Posted July 16, 2014 Author Posted July 16, 2014 Both already been done,it's not hitting full boost untill 5k it's driving me crazy Quote
Ollieh17 Posted July 16, 2014 Posted July 16, 2014 Check for boost leaks, make sure the turbo is healthy. Weak wastegate spring. Boost controller should help, instead of an actuator it controls the external wastegate Quote
5e colin Posted July 16, 2014 Posted July 16, 2014 are you sure u have no boost leak ??? if not then that sounds like tdo5 20g to me Quote
M7WSY Posted July 16, 2014 Author Posted July 16, 2014 No boost leaks atall and just changed the waste gate springs!guess I will have to try the boost controller,any guides to that?lol Quote
M7WSY Posted July 16, 2014 Author Posted July 16, 2014 Defo no leaks Colin,any where on these cars prone to leak if so I will double check,it's defo a tongs ct9 hybrid aswel Quote
Ollieh17 Posted July 16, 2014 Posted July 16, 2014 Boost still shouldnt come in that late. Boost controller wont drop the spool by 2k revs to around where it should be. Got an issue somewhere Quote
M7WSY Posted July 16, 2014 Author Posted July 16, 2014 Starts spooling about 3k and is about 16-18 psi by 4.8 - 5k Quote
5e colin Posted July 16, 2014 Posted July 16, 2014 holy crap a tiny ct9 it should be on full boost at 3k !!!! maybie the rubber membrane/flap in the external waistgate is cracked/leaking thats what i think now Quote
M7WSY Posted July 16, 2014 Author Posted July 16, 2014 Already checked Colin,I just changed the springs on the waste gate and the diaphragm was fine! Quote
