I have just bought a forged engine off here and am going to install it Into my Glanza. It's going to replace a standard engine. The lad has had the engine mapped to 280bhp for a hybrid td04 in an emanage ultimate ecu, when the engine is installed is it ok to run my setup on it? I will be getting it mapped in the next few weeks anyway, im running a blitz k1 ct9 hybrid with jam ecu, sard fuel pressure regulator and gizzmo boost controller? If u need any more specs let me know thanks
If you plan to carry on running the jam ecu then you cannot get it mapped. Just to clarify the engine doesn't need mapping it's the ecu. To answer your question though. It should be fine to run the jam ecu with your setup. I would advise on getting the fuelling checked though for piece of mind :)
Personally id run the jam ecu until you have a turbo worth a forged engine. Forged engine on a Hybrid mapped with a emanage ultimate seems a bit of a waste....in my opinion
My engines gone mate so needed an engine anyway and its always there if i did wanna get more power.
Disagree with that comment about it being a waste, max out the hybrid and see what power you can achieve the spool up will be great
Cheers mate :) I'm having a lightweight flywheel with it as well so that should improve spool a bit to :D
