Devs313 Posted July 22, 2014 Posted July 22, 2014 Anyone got a good tutorial on how to change a cam belt on a 4efte? Found a couple in the tutorial section, but one had no pics, and the other ones pics were not the best. Never done one before, but done everything else maintenance wise on my car so far. Is it worth a shot, or just take it to a mechanic? Quote
The_Notorious_C_A_T Posted July 22, 2014 Posted July 22, 2014 Easy enough to do, bit of a pain for access from what I remember but not mental hard. Quote
grum-glanza Posted July 22, 2014 Posted July 22, 2014 I done one before with a mechanic over my shoulder but it wasn't to hard, the one thing I told again and again was mark sure the timing marks on the cam and crank are perfectly lined up but both taking off the old belt and putting on the new one Quote
Devs313 Posted July 22, 2014 Author Posted July 22, 2014 Been doing some research today and going to have a go. How did you both manage to removed the pulley bolt?Is there a locking tool I can buy to do this? Quote
patman Posted July 22, 2014 Posted July 22, 2014 Grum is right but if your very new to doing this firsty see if you have a good friend who has the time to talk you through it step by step because if you get it wrong it's not bloody good so obviously if it's just you on your own and your unsure about doing something just bite your pride and get it done by a mechanic 👍 Quote
The_Notorious_C_A_T Posted July 22, 2014 Posted July 22, 2014 Pulley bolt I bought a tool to fit into the two holes in the pulley to hold it tight then came off no problem. Quote
Devs313 Posted July 22, 2014 Author Posted July 22, 2014 Cheers for the headsup,....one of my buds whos a mechanic has offered to lend a hand. He asked me to find out whether the locking tool is toyota specific or just a universal one? Quote
The_Notorious_C_A_T Posted July 22, 2014 Posted July 22, 2014 Just anything with 2 prongs that will fit into the holes and brace them to hold it steady. Thing I bought was adjustable, although you could probably make something yourself easily enough, one bar with 2 holes in, and another bar with 2 holes in, join them in a Y shape and on the ends put 2 bolts that will fit into the pulley holes, sorted. Quote
Devs313 Posted July 23, 2014 Author Posted July 23, 2014 Cheers bud. I'll see what we can mock up. Quote
WallaceGlanza Posted July 23, 2014 Posted July 23, 2014 You could also be a bit rougher and jam something against the flywheel teeth... Quote
