string Posted December 20, 2007 Posted December 20, 2007 15s or 16s?want to go 40mm drop after x mas.will 16" x7 wide be aight or will need arch work?will 15" x6.5 be ok or not? need answer quick because i'm orderin tonight. think some rotas with yokos.any thoughtsthanks for the help string Quote
montanajr Posted December 20, 2007 Posted December 20, 2007 15x6.5 are fine. I've just fitted 15x7 on the front and they clear with 45 profile tyres fine. Quote
Sparky Posted December 20, 2007 Posted December 20, 2007 I got 16x7s and they rub a tiny bit on full lock on the inside and when conering hard they rub the outer arch but thats because im about 60+mm on coilys That should be sorted when I get the wide fenders and spacers on though Its upto your personal preference what size though personally but 16s may look a bit big unless your going to mod the exterior a bit etc ;) Quote
Guest Enzo Posted December 21, 2007 Posted December 21, 2007 just remember to stick to an offset of between +38-+40 and you should be fine, Quote
Liam_D Posted December 21, 2007 Posted December 21, 2007 15's in my opinion but its all down to personal preferance. Quote
Bourkey Posted December 21, 2007 Posted December 21, 2007 I personally prefer 15's as the car is easy to throw round corners and general driving. I experienced 16's a month ago and the car didn't feel as playful in my opinion. But Enzo has 18's on his and i doubt his is slow. It all depends on your suspension aswell i guess.Bourkey Quote
Mikey Jay Posted December 21, 2007 Posted December 21, 2007 You guys and your big wheels 14's ftw ;)On a more serious note, think 15's would suit the Starlet better than 16's in terms of visuals and so on Quote
Guest Enzo Posted December 21, 2007 Posted December 21, 2007 for fluidity 14"s for the win for sure, i could do some crazy things with my watanabies with low grip levels15's and 16's for a mix between the two and anything bigger for all out gripa few of jam racings glanza runs 17s at the front with 225 section tyres and 15s on the back with 195s for track racing just to give you guys a gauge ;) Quote
paul w Posted December 22, 2007 Posted December 22, 2007 16"s look better offer better grip and the difference is minimal in weight to the point it really dosn't matter! Quote
