Well today was messing around and remembered I had some led bulbs left over from the astra
So I decided to see what bulbs I had in the rear clusters
To my disappointment I found the big reverse bulbs didnt fit but to my suprise the reverse bulbs were 501 sidelights!! I got loads of these around the house so here we have the before and after!!
Posted ImagePosted ImagePosted Image
If your looking this job was simple
A 10 mm socket and remove the two nuts and pop out the bulb
Make sure you test you got the bulb the right way round.
I might leave it for a little since they did supply me all the leds for the astra, ceed and now have conlmpleated the starlet thanks to there services.
Think I should of put it under the rear lights like the ukso sticker
Really easy mate
I have done led conversion on these bits so far
Number plate
Roof light
Front side lights
Reverse lights
Next jobs are boot light and footwell lights
Also gonna solder in a new led for my ignition light up ring.
