Glanzacoley Posted August 5, 2014 Posted August 5, 2014 Just drained all my oil doing a complete bottom end bearing change how much oil should I put back inMany thanks Quote
JayJ Posted August 5, 2014 Posted August 5, 2014 2.8litres is the right amount with a filter change for 4e-fte. Quote
rinseep82 Posted August 7, 2014 Posted August 7, 2014 (edited) If you changed the bearings ied fill it to the top of the dipstick prime the engine and then check again and top up if needed start it leave it running for a while turn off let it stand for 5-10 min then check again Edited August 7, 2014 by rinseep82 Quote
fremyjay Posted August 7, 2014 Posted August 7, 2014 2.8litres is the right amount with a filter change for 4e-fte. 2.8/2.9L Im worried about why mine took so much as i started with 5 litres and only have 1.5 litres left and its just under the top fill mark =/ Quote
DevonGT Posted August 7, 2014 Posted August 7, 2014 Im worried about why mine took so much as i started with 5 litres and only have 1.5 litres left and its just under the top fill mark =/ That's about right, mine roughly takes that. Quote
TimD Posted August 7, 2014 Posted August 7, 2014 Mine took loads.. I think once my larger filter, and oil cooler had filled up I was almost at 4 litres! Quote
JayJ Posted August 7, 2014 Posted August 7, 2014 Im worried about why mine took so much as i started with 5 litres and only have 1.5 litres left and its just under the top fill mark =/ That's about right, mine roughly takes that. Was your car at level? I did oil and filter change today and used 3 bottles of Redline oil. One bottle is 1 quart = 946ml, making it total of 2.8l and oil level is just below top mark. Quote
fremyjay Posted August 7, 2014 Posted August 7, 2014 Yeah car was level, I will have to re-check it as it said on Google 3 1/2 litres so poured it in measured and left it Quote
DevonGT Posted August 7, 2014 Posted August 7, 2014 Was your car at level? I did oil and filter change today and used 3 bottles of Redline oil. One bottle is 1 quart = 946ml, making it total of 2.8l and oil level is just below top mark. At my tuners work shop. Normally turn engine over to get oil to filter and turbo, then top up as necessary. Quote
fremyjay Posted August 7, 2014 Posted August 7, 2014 Does the gt and glanza sump hold the same amount? Quote
