DavidAshton Posted August 10, 2014 Posted August 10, 2014 What do people generally do in this situation?I have a 20 minute track session at JF2 and I was considering what I should do with my coilovers. They have 30 damper adjustments and tbh I have had them set to soft since the day I fitted them so do:1. Leave them as they are as I am pretty confident where the limits of the car is in its current form?2. Crank the all them way to hard when I get to the track and see what happens?3. Crank them to hard now so I have a week or so getting used to them?Any other suggestions or advise welcome if you have been in the same or similar situation. Also do people bother adjusting camber as well, I don't really want to have to get it tracked again? I have a super neutral setup at the moment. Thanks in advance. Quote
morgey Posted August 10, 2014 Posted August 10, 2014 Put them up to about 20 front and 15-16 rear for track. Its a much smoother surface than on road so you can get away stiffer. I wouldnt worry about camber for one session Quote
davehart Posted August 10, 2014 Posted August 10, 2014 Donny park is a pretty smooth surface so I'd whack em on full hard Quote
