loz180691 Posted August 19, 2014 Posted August 19, 2014 Hi guys I'm running a forged v running 300+ bhp and looking at getting a oil cooler to keep temps sweetQuestion is what kit to go for I need a sandwich plate with the 2 oil cooler ports and 2 sensor ports on.This is what I have found so far is it any good or not http://www.ebay.co.uk/itm/151285200463 Quote
Amjad Posted August 19, 2014 Posted August 19, 2014 There's no thermo in that kit, you will want one otherwise you'll end up having to shield a lot of it for normal driving Quote
loz180691 Posted August 19, 2014 Author Posted August 19, 2014 Ah rite thanks do u know where I can get one with a thermo in with 4 ports Quote
TimD Posted August 19, 2014 Posted August 19, 2014 If you aren't experiencing high oil temps then don't bother.. I struggled to get heat into mine even on track, if all you're using it for is road driving you don't need one. Quote
Amjad Posted August 19, 2014 Posted August 19, 2014 I'd agree with TimD, you'd only ever really need it on track! Mocal do a thermo that has push on fittings but I don't think you can use those lines with one. Quote
loz180691 Posted August 19, 2014 Author Posted August 19, 2014 I did a session at japfest 2 and oil temp got to 100 this normal? Quote
LukeSR Posted August 19, 2014 Posted August 19, 2014 Yeah thats nothing to worry about for a track session! Quote
TimD Posted August 19, 2014 Posted August 19, 2014 100 is about optimal really.. Save your money, or spend it elsewhere. If you start doing track days, not just the odd track session then I would look into fitting an oil cooler, but if it's used on the road it will need to have a thermostat fitted somewhere. Quote
loz180691 Posted August 19, 2014 Author Posted August 19, 2014 Ok thanks for your help guys appreciate it Quote
