1990timeismoney Posted August 20, 2014 Posted August 20, 2014 Hi all had a blitz boost controller installed for a while now and just can not get it to boost what I want.any help on settings etc or what the problem may be will be greatly appreciated. I've also got a strange ticking noise from the engine and unsure what it is or is it something to worry about.Thanks Quote
1990timeismoney Posted August 20, 2014 Author Posted August 20, 2014 I had a profec a and was the best controller I've had Brought two as a spare it was that good but unfortunately sold them along with my old car.have u check the dip switches on the back Quote
Ollieh17 Posted August 20, 2014 Posted August 20, 2014 No switches on the back of the profec spec 2 Quote
BIGGFOOT Posted September 16, 2014 Posted September 16, 2014 Allright lads I'm having same problem on emb(just fitted) but I haven't got a boost control unit but I'm running external wastegate is the spring inside wastegate only thing that could of gone wrong? Any help much appreciated 👍 Quote
turbominicooper Posted September 16, 2014 Posted September 16, 2014 have you got the sensor plumbed in correctly? one side is 'com' and should go to the actuator (I think) Quote
1990timeismoney Posted September 18, 2014 Author Posted September 18, 2014 Still seem to be getting the same problem can't hear any leaks and actuator seems ok but am in the process of measuring for a new one.Could the old hks bov not holding boost Quote
BIGGFOOT Posted September 19, 2014 Posted September 19, 2014 I've sorted it with a manual boost controller tap type thing? (Not sure what it's called lol) plumbed it into my external vacuum pipes and works a treat now at 10 psi pulling hard lads 👍 also check your external isn't leaking ,I've popped a new 38mm gasket in to be sure of no leaks Quote
1990timeismoney Posted September 22, 2014 Author Posted September 22, 2014 Still can't get boost past .4 starting to bug me now actuator is a hks one feels good as it not that used.got a blitz boost controller to.wanting to try the actuator to another but has enoying size bolts so needs a bracket which I'm waiting to measure any other suggestions much appreciated Quote
BIGGFOOT Posted September 23, 2014 Posted September 23, 2014 Try it without the electronic boost controller and possibly go external wastegate pal mines boosting hard now on 10 psi with a manual tap type boost controller set up on vacuum line before ex wg, hope this helps mate .... What ecu are you running? Quote
