if you have a RRFPR it will give you some level of mechanical adjustment to correct the fuel pressure if not look into getting one asap :thumbsup:
could also try compression test to rule out rings.....
mines was the same mate last week, been to a tuning place and had a health check done because my oil was strong petrol and it came back healthy 150 psi across all 4 smoke test and leak down test. everything seems fine, so unless your getting smoke n stuff i wouldnt worry about it
  • 1 month later...
Mine the same as this :( oil has a very strong smell of petrol, pretty sure it's over fueling though, had it dyno'd Saturday and fuel/air was high at low revs but okay at high revs
by the way guys i put up a post about this not that long ago, advised it was fine etc etc and now my engine has been stripped as ive lost compression in 3 cylinders.
compresison came back fine when tested before hand etc but it was obviously a problem for mine.
