andy91145 Posted August 21, 2014 Posted August 21, 2014 (edited) Can you extend the harness on the fuel pump and stick a switch on it to make a kill switch? I don't really want a battery cut as I need my alarm etc to work but for piece of mind I would prefer to disable the fuel pump Edited August 22, 2014 by andy91145 Quote
morgey Posted August 21, 2014 Posted August 21, 2014 Cant see why not. Splice in run it through a simple switch and back inline again. Hide it out the way and away you go. Quote
TD04HYBRID Posted August 22, 2014 Posted August 22, 2014 I done it on mine mate! Cut into the live going to the fuel pump/ run a live from there to the switch and take a ignition live to the switch also put a inline fuse in the wire going from the pump to the switch! I have a set of switches if your interested Quote
TD04HYBRID Posted August 22, 2014 Posted August 22, 2014 Better than a alarm system if you hide it in the right place ;) Quote
andy91145 Posted August 22, 2014 Author Posted August 22, 2014 I done it on mine mate! Cut into the live going to the fuel pump/ run a live from there to the switch and take a ignition live to the switch also put a inline fuse in the wire going from the pump to the switch! I have a set of switches if your interested Where did you take your ignition live from? Quote
andy91145 Posted August 22, 2014 Author Posted August 22, 2014 Also what size fuse should be used? Quote
AlancEP82 Posted August 22, 2014 Posted August 22, 2014 First place someone will look when on the rob lads Quote
TD04HYBRID Posted August 23, 2014 Posted August 23, 2014 I used a 15amp! And there have fun looking if you hide it! Quote
AlancEP82 Posted August 23, 2014 Posted August 23, 2014 Tell everyone ^ Shouldn't be putting stuff like this up only helping the robbing cunts Quote
