id workz oil feed fitment??
Right so ive managed to squeeze it between the filter and silicone hose just, not entirely happy with how they fit. Surely all these premade td04 oil feeds should have a straight connector instead of a banjo on the m14 side to avoid this.
That's how most suppliers have them made and they fit perfectly if you rotate it to the correct position. I've fitted several myself without issues, and we've sold dozens now! Is yours going up behind the turbo or in front?
