Found my controller after misplacing it weeks ago, going to fit it today, Where does the vacuum line coming from the back of the unit plumb into? read the instructions 10+ times now and still unsure? Says something about plumbing it into frp vacuum line, is this correct?
Thanks
James
Never used the controller personally but I'd suspect that you just need a vacuum/pressure feed from the manifold. Better off confirming it with someone that uses the controller though.
Yup, as said above, straight to the inlet manifold
Gotcha cheers lads :)
