Hi,
I've removed the stock rubber out of the rear engine mount on my EP85 (with a knife, hacksaw, chisel and a big hammer lol) to replace it with a polyurethane one but the poly mount I have for the EP82 is slightly too small to fit...
Can anybody tell me what poly mount will fit, or am I better off just fabricating one myself like this: http://www.mgmetrocup.co.uk/forum/index.php?topic=265.0 ?
Cheers
Edited by sdutton007
Do you still have the stock engine? As with a 4efte in place you need to keep the ring for the rear. the other two fit ok without it.
Why would the engine make any difference? Regardless, it will be a forged 4e once I finish doing the engine bay and drop the engine in lol
I've just measured the mount and it seems to be 66mm without the ring or 62mm with the ring.
I assume I have the stock EP85 mount which is completely different to the EP82 one. I will get a pic up shortly...
I dont think the poly bushes were made for those mounts, ive had mine off and they are physically different to both types of 82 mounts.
Maybe some really good tiger seal type shit would hold it in properly ?
Thanks for the replies. I will have to consider my options:
- Getting machinist to make a 1mm ring
- Use tiger seal or similar to fill gap
- Making my own poly mount
- Find 66mm poly mount with same length
