Starlet Wayne Posted September 1, 2014 Posted September 1, 2014 Car starts but when i touch the Accelerator it cuts out. Quote
fremyjay Posted September 1, 2014 Posted September 1, 2014 More info needed bud, has it only just started doing it or has it always done it?? anything been played with or changed lately Quote
Starlet Wayne Posted September 1, 2014 Author Posted September 1, 2014 More info needed bud, has it only just started doing it or has it always done it?? anything been played with or changed latelyI'm doing a Sportif 4efte conversion its always done it, ive got no exhaust on it, could it be rotor Arm and distributor cap? Its it starts up fine look at fueling and its seems to be greeting to the fuel rail, its got standard n/a fuel pump but know you can use that . Quote
aaddzz123 Posted September 1, 2014 Posted September 1, 2014 How does it idle? video? Are you running the map sensor? Right ECU? How does it cut out is it a cough and go or just dies without trying etc, any smoke out the exhaust? Going to need some decent information to try and help with this one mate. Having running problems after doing an engine conversion leaves so many things to be checked and considered. Quote
Starlet Wayne Posted September 1, 2014 Author Posted September 1, 2014 How does it idle? video? Are you running the map sensor? Right ECU? How does it cut out is it a cough and go or just dies without trying etc, any smoke out the exhaust? Going to need some decent information to try and help with this one mate. Having running problems after doing an engine conversion leaves so many things to be checked and considered.It ildes spots on, it jut cuts out i can slowly rev it to about 2k then it cuts out completely, yep its glanza Ecu , dont know as dont have exhaust on ATM, I'll try and get video tonight, Quote
aaddzz123 Posted September 1, 2014 Posted September 1, 2014 Is the throttle position sensor on and calibrated? Idle control valve? I believe the lambda sensor controls fueling up to 2k and then it switches over to the ECU or something like that. Quote
Starlet Wayne Posted September 1, 2014 Author Posted September 1, 2014 Is the throttle position sensor on and calibrated? Idle control valve? I believe the lambda sensor controls fueling up to 2k and then it switches over to the ECU or something like that. Yep all on. Hmm I'm gonna have to spend more hours on it lol Quote
Starlet Wayne Posted September 1, 2014 Author Posted September 1, 2014 Ignition timing???We're bouts ignition timing? Quote
fremyjay Posted September 1, 2014 Posted September 1, 2014 You need a timing light to check and adjust it, http://www.toyotagtturbo.com/forums/showwiki.php?title=How+to+set+timing Quote
Starlet Wayne Posted September 1, 2014 Author Posted September 1, 2014 Will get it look at thanks pal. Dont think it will be this tho, Quote
fremyjay Posted September 1, 2014 Posted September 1, 2014 Best person to get onto would be dangleestarlet as he done his conversion not too long ago Quote
Starlet Wayne Posted September 1, 2014 Author Posted September 1, 2014 Best person to get onto would be dangleestarlet as he done his conversion not too long agoYeah I'll give him a bell, ive gotta get few things done first because it could be them. Quote
ramses Posted September 2, 2014 Posted September 2, 2014 Hiyou can have a lot of things that result to the same symptome:1/check timing2/chek fuel line - fuel pump3/check your TPS (sorry it is not variable)4/ignition system > coil? >igniter>plug Quote
