primesera Posted September 2, 2014 Share Posted September 2, 2014 (edited) How doo guys. Could anyone listen to my engine from the YouTube link and tell me if they think it's serious or just a noise from it not running regularly for the past 2 years ( probably been started 5 times in 2 1/2 years)>http://youtu.be/bcW0BXi8YsgI remember the engine always being a little tappy, probably the normal noise but it does seem to be noisier than I remember. I think the noise is coming from the bottom pulley area, my first thought was the water pump but I'm not so sure now. The noise seems to only be on tick over.Any thoughts would be great Edited September 2, 2014 by primesera Quote Link to post Share on other sites
mattglanza79 Posted September 2, 2014 Share Posted September 2, 2014 Don't wanna alarm you mate and someone else might shed some light but mine was doin similar. Sounded like a loose brkt. Then the shells went Quote Link to post Share on other sites
Sefton-EP91 Posted September 2, 2014 Share Posted September 2, 2014 Mine made the same noise. Mine was the bottom pulley catching on the timing cover on the bottom. Whilst the engine is running just push just above the bottom pulley on the timing belt cover. Be careful obviously because the engine will be running. When I done this the noise went. And as soon as you let go the noise comes back. Hope this helps mate Quote Link to post Share on other sites
Matt1878 Posted September 2, 2014 Share Posted September 2, 2014 Mine currently does this bot not quite as noticeable. The lower cambelt case has warped due to engine heat and catches on the pulley. Quote Link to post Share on other sites
primesera Posted September 2, 2014 Author Share Posted September 2, 2014 Thanks for the replies. I'm hoping it's just the case cover rather than the shells :-)I'll start it tomorrow night and check Quote Link to post Share on other sites
