Anyone done this? Cant seem too find anything on this . If so how difficult was it , as mine are about fooked and was going to have a crack myself with a rebuild kit
Cheers
Will
I have just done it mate its a fiddly job but can be done if your any way good with your hands first one was a learning curve second one i have still to do but id say ill knock it out in 20 minutes
just make sure you take the time to clean any moving part and use the special grease provided
Edited by matty gt
Its very simple but as Matty said just make sure everything is as clean as possible.
Also give yourself plenty of time because if the seals have leaked you may need new pistons as well if they are corroded.
