fremyjay Posted September 18, 2014 Posted September 18, 2014 (edited) Right my gearbox is all fitted, brought driveshafts non lsd as that is what the box is and the driveshaft on drivers side wont reach the hub it is about 3 inches off and it is the longer of the two shafts so i havent put the wrong one on??? why would this be, could i have 1 lsd shaft and one oem?? Edited September 18, 2014 by fremyjay Quote
5e colin Posted September 18, 2014 Posted September 18, 2014 you sure the other shaft is from ep82/91 Quote
fremyjay Posted September 18, 2014 Author Posted September 18, 2014 These are the shafts, my gearbox is non-lsd, so im guessing these are lsd Quote
akyakapotter Posted September 18, 2014 Posted September 18, 2014 (edited) Measure them ill check my spare shafts bud your missing the damper off the long one Edited September 18, 2014 by akyakapotter Quote
fremyjay Posted September 18, 2014 Author Posted September 18, 2014 Okay cheers dude, its a pain as wanted to get my bloody shafts on haha Quote
5e colin Posted September 18, 2014 Posted September 18, 2014 on my gt there is a reces in the middle of the long shaft for the round rubber im not sure if thats stock on the v but it could be a different drive shaft u have there Quote
akyakapotter Posted September 18, 2014 Posted September 18, 2014 on my gt there is a reces in the middle of the long shaft for the round rubberim not sure if thats stock on the v but it could be a different drive shaft u have thereYou can see where it was its been removed Quote
fremyjay Posted September 18, 2014 Author Posted September 18, 2014 (edited) Yeah seen the longer shafts have a rubber in the middle, but as above there is a mark where it was Edited September 18, 2014 by fremyjay Quote
5e colin Posted September 18, 2014 Posted September 18, 2014 nope on the turbo shafts there is thinner thicker metal at the spot for the ring/rubber to hold it in place Quote
fremyjay Posted September 18, 2014 Author Posted September 18, 2014 A few guys on facebook reckon the shorter shaft is a lsd one, as drivers side is the only different one Quote
fremyjay Posted September 18, 2014 Author Posted September 18, 2014 So im guessing with cup on the end the smaller shaft would be 27 1/2 bud? if so its the longer shaft i have that is wrong Quote
fremyjay Posted September 18, 2014 Author Posted September 18, 2014 Excellent your a legend, thanks again bud Quote
5e colin Posted September 18, 2014 Posted September 18, 2014 you see next to the rubber i moved it a bit you can see the extra meat on the bar Quote
fremyjay Posted September 18, 2014 Author Posted September 18, 2014 Yes that's the one I'm after now bud Quote
5e colin Posted September 18, 2014 Posted September 18, 2014 i think your long shaft might be from 4efe corolla ?? Quote
