_JT_ Posted September 18, 2014 Posted September 18, 2014 Hi everyone,Just had inner cv boot changed on my glanza. Car has got LSD, have checked the chassis plate which says C56 so it had Redline gear box oil put back in which according to the mechanic was the same that came out. The car now drives horrendously and has a dreadful judder coming from the diff and banging when turning which it never did before. Please can someone helpAdvice appreciated Quote
daniel_g Posted September 18, 2014 Posted September 18, 2014 You'll probably need a friction modifier in with the oil (depending on what kind of LSD it is) Quote
_JT_ Posted September 18, 2014 Author Posted September 18, 2014 Ok that sounds promising. How can you tell what diff it is ? The previous owner hasn't touched the diff im the 2nd uk owner and know the previous very well so it may have been apart in Japan...? Quote
_JT_ Posted September 24, 2014 Author Posted September 24, 2014 In case it helps anyone else... 2.2L of Millers CRX LS 75x90 NT Fully synth with LSD additive has sorted me right out Drives perfect now Quote
