raddys1 Posted September 22, 2014 Share Posted September 22, 2014 Just got a cusco lsd box to go in my glanza running 170-200 bhp (approx)I'm not running silly brake so I don't want to pay £300 for a stage 2 clutchSo I'm thinking of a standard exedy clutch (heard mixed stories about stage 1 so il leave that)Is there anything else I need to doSomeone said about skimming the plate?Also what gear oil, will 75-90 do?Regards Quote Link to post Share on other sites
maddox710 Posted September 22, 2014 Share Posted September 22, 2014 If you're buying a new clutch why would you need to skim the pressure plate? As far as gear oil goes that's a great idea Quote Link to post Share on other sites
raddys1 Posted September 22, 2014 Author Share Posted September 22, 2014 Well that's what I was thinking because surely the new clutch would bed into the old plate, just that some1 said get it skimmed so it don't shudder :S I'm abit of a noob when it comes to glanzas and tuning Quote Link to post Share on other sites
raddys1 Posted September 22, 2014 Author Share Posted September 22, 2014 Sorry not plate, I meant does the flywheel need skimming Quote Link to post Share on other sites
Gilly Posted September 22, 2014 Share Posted September 22, 2014 If your getting a new clutch its an idea to skim the flywheel face so it has a fresh surface for the clutch to bed in properly. If the pennys do stretch to it i would get a paddle clutch just to make things easier if you wanted to go for more power in the future. Depending on how you drive the car the LSD will put more strain on the clutch also. I am running a Cusco MZ 1-way diff and its lovely and the oil i use is redline 75w-90s non Slip. you can only get it in bottles fractionally just under a litre but two bottles will be enough. Quote Link to post Share on other sites
oilman Posted September 22, 2014 Share Posted September 22, 2014 That's a very good oil. http://www.opieoils.co.uk/p-1017-red-line-synthetic-gear-oil-75w-90ns-gl5-non-limited-slip.aspx Cheers Tim Quote Link to post Share on other sites
raddys1 Posted September 22, 2014 Author Share Posted September 22, 2014 Sweet thanks for the help guys cheers Quote Link to post Share on other sites
