jonnygt Posted September 27, 2014 Posted September 27, 2014 Need a new one, sooner the better, anybody have a idea which one i need a does any clutch fit long as its for a starlet ? N/a clutch all the same? I think they but just wanna ask so i can buy one soon Thanks Quote
mikey4410 Posted September 27, 2014 Posted September 27, 2014 N/a clutch is no good, different diameter.you need an exedy stage one clutch if you running upto 190 ish.Anything around and over would personally go for a six puck and its peace of mind knowing your clutch will always be manly enough for future upgrades you do to your car. Quote
5e colin Posted September 27, 2014 Posted September 27, 2014 200mm starlet clutch there al the same Quote
mikey4410 Posted September 27, 2014 Posted September 27, 2014 And whatever you do get your clutch skimmed or buy a new flywheel.I opted for flywheel as I wanted it all spot on without a shadow of a doubt Quote
Idrees Posted September 27, 2014 Posted September 27, 2014 It's a 4E-FE, so you need a 200mm 4E-FTE clutch as mentioned by Colin. Quote
Gainzy Posted September 27, 2014 Posted September 27, 2014 I would suggest buying an oem release bearing and check the clutch fork while it's out I have seen split forks or tiny cracks not saying that's the problem just saying to check it, probably fine Quote
jonnygt Posted September 29, 2014 Author Posted September 29, 2014 Cheers mate. Hopefully get it sorted by the weekend along with the bodywork! Cant bloody wait lol Quote
