Car feels like it's being pulled like its lagging and sounds like its missfiring sometimes , changed plugs , leads , dizzy , really need help guys anyone got any idea?
Yeah the code is speed sensor , really don't know what to do
Yeah I've got a fuel cut defender not sure how to check it ?
basically ecu code 42 Vehicle Speed Sensor (VSS)
No speed sensor signal to ECU when loaded driving condition with engine speeds 2000 to 5000 rpm. in 5th gear driving
For 8 seconds or more.
Thats from someone else with you problem
I get it evey now and then just ignore it I just ignore it never got to the bottem of it.
42 is no spd signal for 8 seconds when engine speed is between 2500rpm & 5000rpm and coolant temp is below 80c except when racing engine
Edited by akyakapotter
