Ryan5793 Posted October 5, 2014 Share Posted October 5, 2014 started up my car after a rebuild and na conversion today all seems good but it hunts all the time? on warm start up it seems to idle ok until i touch the throttle then it will keep reving from 1500-2000 making it really difficult to drive as it jolts you about. first thought was an air leak so we had ago with the vacuum hoses and couldnt work it out as was just guessing really. Also plugged in some of the air-con sensors which seemed to help at first but its still there. So any tips or pointers would be great so i can have another go with it tomorrow cheers Quote Link to post Share on other sites
_shaun_ Posted October 5, 2014 Share Posted October 5, 2014 My money would be on a vac leak if there's a local garage with a smoke tester id ask them to check it takes them 10mind and saves you what could be hours of searching Quote Link to post Share on other sites
