As above, you like to go externally gated with my ct9 who's got what.?
I believe I need;
Manifold
Wastegate
Welded up turbo waste gate
Ebc
What else?
Beany :)
if your on a budget you could do this like i did , can be done to any manni if you can weld a bit al you need is then small section of pipe and 90% corner and a flange with waste gate and weld up the penny in the turbo can al be done for under 100
Yeah, I've got a mig welder, an I can weld, never really thought of a DIY, which is strange seen as I built a full cage, an other parts for my old car.
Do you have more info/pics?
Be a good read up :)
Also what else did you need?
Any parts I've missed off the list?
dont have more pics sorry , but you need
2x 100x50mm x10 metal plate
2 x 90% bend and small strait pipe ( depends where you locate the wastegate ) and wa manni your adding to
thats it really
To weld a wastegate up on a ct9 you need high nickel content tig rods as its best with iron housings
they are expensive rods and a pain to weld.
if you dont use nickel cracks and splitting away occurs.
