Hi guys, basically in rebuilding my engine and when I sent the engine off to get rebored and honed. They took my crankshaft off to be measured and reground. Which is all fine now but I've got a box off all the main bearing caps and as I'm putting new acl bearings in. I'm now assuming that because the main caps are numbered 1-5 they go in order of timing belt side. But before I torque it down I wanted to double check if someone on here new. As we all no what happens when we assume everything...thanks
Couldn't find the wiki, but yea I assumed that they would be nearest one to the timing side, as it's pretty much the rule if thumb isn't it? I just wanted to double check. Cheers guys 👍
