Ashleyr88 Posted October 26, 2014 Share Posted October 26, 2014 What the max bar to run on a standard turbo with up rated injectors and front monted intercooler Quote Link to post Share on other sites
5e colin Posted October 26, 2014 Share Posted October 26, 2014 same as with stock injectors max 1 bar Quote Link to post Share on other sites
Ashleyr88 Posted October 26, 2014 Author Share Posted October 26, 2014 What bhp will I be getting from 1bar just got the car and it's had a few bits done already Quote Link to post Share on other sites
5e colin Posted October 26, 2014 Share Posted October 26, 2014 around 170 / 180bhp or there abouts depending on spec and condition of the engine to Quote Link to post Share on other sites
Ashleyr88 Posted October 26, 2014 Author Share Posted October 26, 2014 It's got 62,000m so not to bad Quote Link to post Share on other sites
mikey4410 Posted October 26, 2014 Share Posted October 26, 2014 1 bar max on stock ct9.defo wouldn't go over that.out of efficiency. Will give circa 180 bhp. Quote Link to post Share on other sites
Ashleyr88 Posted October 26, 2014 Author Share Posted October 26, 2014 Also iderling really bad reving up and down between 1000 and 2000rpm and gets really hot really quick Quote Link to post Share on other sites
5e colin Posted October 27, 2014 Share Posted October 27, 2014 It's got 62,000m so not to bad its clocked Also iderling really bad reving up and down between 1000 and 2000rpm and gets really hot really quick and ere ^^^^^ is your answer to it :) to that problem check the wax valve under the tb and iacv valve if there still working Quote Link to post Share on other sites
