Ollieh17 Posted November 5, 2014 Posted November 5, 2014 Getting confused here. Looking to replace the oil pressure switch(plug) and cant find where it is on the block. Under the intake i thought is the knock sensor, manifold side is the pressure relief valve and on my block no other plugs Quote
turbo Grant Posted November 5, 2014 Posted November 5, 2014 It's on the front of the engine gear box side. 1 wire connector. The oil pressure relief valve is inside the sump Quote
Ollieh17 Posted November 5, 2014 Author Posted November 5, 2014 I replaced one that looks like thisBut there is no where for a plug so bought one of these also Quote
WallaceGlanza Posted November 5, 2014 Posted November 5, 2014 The first one is what you need for the glanza, all that attaches to it is a spade connector with a plastic cover,its a yellow wire. Quote
Ollieh17 Posted November 5, 2014 Author Posted November 5, 2014 Ah right, waste of £8 for the second one Quote
