Ollieh17 Posted November 5, 2014 Share Posted November 5, 2014 Getting confused here. Looking to replace the oil pressure switch(plug) and cant find where it is on the block. Under the intake i thought is the knock sensor, manifold side is the pressure relief valve and on my block no other plugs Quote Link to post Share on other sites
turbo Grant Posted November 5, 2014 Share Posted November 5, 2014 It's on the front of the engine gear box side. 1 wire connector. The oil pressure relief valve is inside the sump Quote Link to post Share on other sites
Ollieh17 Posted November 5, 2014 Author Share Posted November 5, 2014 I replaced one that looks like thisBut there is no where for a plug so bought one of these also Quote Link to post Share on other sites
WallaceGlanza Posted November 5, 2014 Share Posted November 5, 2014 The first one is what you need for the glanza, all that attaches to it is a spade connector with a plastic cover,its a yellow wire. Quote Link to post Share on other sites
Ollieh17 Posted November 5, 2014 Author Share Posted November 5, 2014 Ah right, waste of £8 for the second one Quote Link to post Share on other sites
Ollieh17 Posted November 5, 2014 Author Share Posted November 5, 2014 Cheers though guys! Quote Link to post Share on other sites
