I've bought a second hand forged engine.
Before i take the car for mapping at TD i would like to drive it round the block to make sure its not leaking anything ect.
At the moment i just have a standard ECU fitted (TD are fitting emanage and boost controller when i go up)
I have a TD05 turbo with a external wastegate with a .8bar spring.
Should i put a lower spring in to take it round the block? or is it ok to keep the .8bar spring in?
Anything else i should look out for?
Cheers,
Charlie
Got a wideband? You might find the standard ecu fuels the td05 fine
Don't have a wideband at the moment no. Just want to make sure its not leaking and i'll trailer it up to TD.
