When I go around a right hand bend at any speed, there is what I can only describe as a rotational sound like there is a little play somewhere. It Increases with speed also.
There is no play in the wheel itself as I checked when I had the car on the ramp. My wheels are in perfect condition too. No dings anywhere.
Could this be CV joint?.. It doesn't click when on full lock and when going around a left bend there is no noise.
Help to rule out things would be appreciated.
Edited by Matt1878
Sounds like mine when the CV joint had gone.
If I were you when you change the bearing I would knock the joint off and confirm the spline count just in case it isn't the bearing.
