As above has anyone been able to leave the a/c in the stock place after installing a fmic on a ep82 or even 91 , pictures of how you piped it out would help Ino its a lot of hassle just to keep the air con also advice on relocating the air filter would I have any problems because I've ac still in
It would be a lot of hassle as they are all designed to fit without the ac you could run an rx7 tmic or even brand new stock topmounts they are capable of 1 bar boost cooling
Managed to fit mine mine with the AC, long route piping, only thing is the crash bar had to be removed. In the end I got rid of the ac and put the crash bar back.
The longer the pipe route the longer the spool time response the ac weighs around 16kg all in all fmic will give you the best cooling for your engine.
JAM fmic is stock rad and A/C friendly, also short route piping. Finding one is another story ;-)
Whitestar has also stock rad and A/C, he's running Ebay kit IIRC.
Because JAM race car :D:D:D
We all know unless your in Cambodia the only thing ac does is slow you down lol :p
Haha, you haven't experienced Finnish summer.. which is short and mostly no snow :D
