Ain't the top one for the ignitor? And the other one for top of gearbox for reverse light?
Both of them are plugged in already? The top one followed the injector loom and other is by gearbox, I can't find where they go for life of me but proberly something simple I've missed tbh the gt loom was a mess aswell
Did it have aircon? There's normally 2 vaccum sensors on the firewall that people get rid if , one for brakes idle and one for aircon idke
Yea it did nd all the sensors for air con are still there and plugged in, if I cant find where they go I will fire in up and see what it does lol
Il go and check in mine for you now
Send me some better pics of where the plugs are on facebook
I'm not shore the plugs are ment to be where they are the top one is above break server nd lower one is just sat above gearbox around 30cm length on each one
Knock sensor?
Already wired in along with, injectors, inlet sensors, ignitor etc, reverse switch, thermostat housing sensors, starter, alternator and the sensor under clutch slave
if al sensors are connected and it aint trowing the engine light leave it ben :) :)
the black is for vsv on my gt for sure
I've only cranked it over so far but will leave them if needs be, have you got a pick of your vsv as glanza bays are slightly different and that's all I've ever worked on
ere ben you see where this wire goos near the left of oil cap and curves around the brake fluid resevoir thats it there
will get better pic in morning this is an old 1
Edited by 5e colin
thats becouse the vsv and 3mm line is gone !!!
OR does not exist on a V ha ha
just getting a bit of confusion going here ha ha
fuck that its an ep82 i see ha ha its supposed to be there
So basically cut the that wire off then if it runs lol wonder what the others for then hmmmm
ya un needed ben i havent got that anymore either
Sweet I did think the loom was more on.the gt then the glanza lol any idea about the vac line position I need
Remember now how the vac lines got as there for the ac so will.blank off but what about the thin black ones from charcoal canister can i sack them off aswell
