Glanza-Ben Posted November 20, 2014 Share Posted November 20, 2014 Need to know where these two go as I've forgot Quote Link to post Share on other sites
dangeestarlet Posted November 20, 2014 Share Posted November 20, 2014 Ain't the top one for the ignitor? And the other one for top of gearbox for reverse light? Quote Link to post Share on other sites
Glanza-Ben Posted November 20, 2014 Author Share Posted November 20, 2014 On 11/20/2014 at 6:54 PM, dangeestarlet said: Ain't the top one for the ignitor? And the other one for top of gearbox for reverse light?Both of them are plugged in already? The top one followed the injector loom and other is by gearbox, I can't find where they go for life of me but proberly something simple I've missed tbh the gt loom was a mess aswell Quote Link to post Share on other sites
dangeestarlet Posted November 20, 2014 Share Posted November 20, 2014 Did it have aircon? There's normally 2 vaccum sensors on the firewall that people get rid if , one for brakes idle and one for aircon idke Quote Link to post Share on other sites
Glanza-Ben Posted November 20, 2014 Author Share Posted November 20, 2014 On 11/20/2014 at 7:12 PM, dangeestarlet said: Did it have aircon? There's normally 2 vaccum sensors on the firewall that people get rid if , one for brakes idle and one for aircon idkeYea it did nd all the sensors for air con are still there and plugged in, if I cant find where they go I will fire in up and see what it does lol Quote Link to post Share on other sites
dangeestarlet Posted November 20, 2014 Share Posted November 20, 2014 Il go and check in mine for you now Send me some better pics of where the plugs are on facebook Quote Link to post Share on other sites
Glanza-Ben Posted November 20, 2014 Author Share Posted November 20, 2014 Need to know where the long black pipes goes aswell and which vac lines connect on the other arrowed part Quote Link to post Share on other sites
5e colin Posted November 20, 2014 Share Posted November 20, 2014 top 1 is for vsv going to inlet/charcoil canister i think ???? 2nd lambda 2 ???? Quote Link to post Share on other sites
Glanza-Ben Posted November 20, 2014 Author Share Posted November 20, 2014 On 11/20/2014 at 7:15 PM, dangeestarlet said: Il go and check in mine for you now Send me some better pics of where the plugs are on facebookI'm not shore the plugs are ment to be where they are the top one is above break server nd lower one is just sat above gearbox around 30cm length on each one Quote Link to post Share on other sites
Glanza-Ben Posted November 20, 2014 Author Share Posted November 20, 2014 On 11/20/2014 at 7:17 PM, 5e colin said: top 1 is for vsv going to inlet/charcoil canister i think ????2nd lambda 2 ????Both lambda plugs are tucked away already as never use them Quote Link to post Share on other sites
morgey Posted November 20, 2014 Share Posted November 20, 2014 Knock sensor? Quote Link to post Share on other sites
5e colin Posted November 20, 2014 Share Posted November 20, 2014 On 11/20/2014 at 8:13 PM, morgey said: Knock sensor? single wire morgey Quote Link to post Share on other sites
Glanza-Ben Posted November 20, 2014 Author Share Posted November 20, 2014 On 11/20/2014 at 8:13 PM, morgey said: Knock sensor?Already wired in along with, injectors, inlet sensors, ignitor etc, reverse switch, thermostat housing sensors, starter, alternator and the sensor under clutch slave Quote Link to post Share on other sites
dangeestarlet Posted November 20, 2014 Share Posted November 20, 2014 Intake temp sensor? Idle control valve sensor? Quote Link to post Share on other sites
5e colin Posted November 20, 2014 Share Posted November 20, 2014 if al sensors are connected and it aint trowing the engine light leave it ben :) the black is for vsv on my gt for sure Quote Link to post Share on other sites
Glanza-Ben Posted November 20, 2014 Author Share Posted November 20, 2014 On 11/20/2014 at 8:21 PM, 5e colin said: if al sensors are connected and it aint trowing the engine light leave it ben :)the black is for vsv on my gt for sureI've only cranked it over so far but will leave them if needs be, have you got a pick of your vsv as glanza bays are slightly different and that's all I've ever worked on Quote Link to post Share on other sites
5e colin Posted November 20, 2014 Share Posted November 20, 2014 will take first thing in the morning ben its pitch black where my ride is parked Quote Link to post Share on other sites
Glanza-Ben Posted November 20, 2014 Author Share Posted November 20, 2014 On 11/20/2014 at 8:28 PM, 5e colin said: will take first thing in the morning ben its pitch black where my ride is parkedAppreciate it bud thanks Quote Link to post Share on other sites
5e colin Posted November 20, 2014 Share Posted November 20, 2014 (edited) ere ben you see where this wire goos near the left of oil cap and curves around the brake fluid resevoir thats it there will get better pic in morning this is an old 1 Edited November 20, 2014 by 5e colin Quote Link to post Share on other sites
Glanza-Ben Posted November 20, 2014 Author Share Posted November 20, 2014 Hard to make out in that picture Mine has nothing on the left side apart from power steering Quote Link to post Share on other sites
5e colin Posted November 20, 2014 Share Posted November 20, 2014 thats becouse the vsv and 3mm line is gone !!! OR does not exist on a V ha ha just getting a bit of confusion going here ha ha fuck that its an ep82 i see ha ha its supposed to be there Quote Link to post Share on other sites
Glanza-Ben Posted November 20, 2014 Author Share Posted November 20, 2014 On 11/20/2014 at 8:50 PM, 5e colin said: thats becouse the vsv and 3mm line is gone !!!OR does not exist on a V ha hajust getting a bit of confusion going here ha ha fuck that its an ep82 i see ha ha its supposed to be thereSo basically cut the that wire off then if it runs lol wonder what the others for then hmmmm Quote Link to post Share on other sites
5e colin Posted November 20, 2014 Share Posted November 20, 2014 ya un needed ben i havent got that anymore either Quote Link to post Share on other sites
Glanza-Ben Posted November 20, 2014 Author Share Posted November 20, 2014 On 11/20/2014 at 8:53 PM, 5e colin said: ya un needed ben i havent got that anymore eitherSweet I did think the loom was more on.the gt then the glanza lol any idea about the vac line position I need Quote Link to post Share on other sites
Glanza-Ben Posted November 20, 2014 Author Share Posted November 20, 2014 Remember now how the vac lines got as there for the ac so will.blank off but what about the thin black ones from charcoal canister can i sack them off aswell Quote Link to post Share on other sites
