Ollieh17 Posted November 30, 2014 Posted November 30, 2014 Removed the abs from my glanza, now wondering if i can use non-abs disk brakes on the rear now? Quote
fiddlersport Posted November 30, 2014 Posted November 30, 2014 pretty sure the discs are the same, most members remove the abs and didnt mention nothing about disc change, fire a pm at one of the traders, they should be able to give accurate information ! Quote
Ollieh17 Posted November 30, 2014 Author Posted November 30, 2014 Its only because mine need changing and i knowNon abs are a fair bit cheaper Quote
morgey Posted November 30, 2014 Posted November 30, 2014 Yeah you can but check to see if they come with seals as i went from abs to non abs and the non abs ones didnt come with seals so has to buy some separate. Quote
