I have just fitted a new clutch and when the im driving round corners or turning im getting a clunk/knocking noise.
I've had the car up on the ramps and there dosent seem to be anything loose or that can any one shed some light on my problem.
cheers
squeak
Hi Rob I've just got a standard flywheel.
It must be the drive shaft or as you's say it could be the suspension.
I wont manage to sort it till wkend but all let you no how i get on.
squeak
is it a clunk you say or is it more of a clicking noise?
mine was drive shaft when it was clicking
my mates was suspenssion when it was clunking
cheers
sam
Sonds like a knackered CV joint to me.
If you had to remove the driveshaft when doing the cluch, you may have split the CV boot. Once all the grease comes out the dry joint starts knocking on full lock.
Oz
I've been at the car today and all the cv joints are ok the suspension is ok and everything that i toke off for changing the clutch are ok.
Could it be my diff thats causing the problem...
I just cant figure it out and its really pissing me off. :)
  • 3 weeks later...
