its squeeking when i apply clutch and its a small squeek from inside but louder from the outside, is it shit cables or something to do with gearbox?
does the nosie go once clutch fully depressed? if so it prob ya release bearing
no down near completely pressed. to me it sounds as if it needs wd40 but i wouldnt know where to spray it lol but when i get out the car and do it sounds like its coming from the engine area
does it do it all the time eg drving or wen just at idle ?
only noticed about 4-5 days ago and now im fully aware of it. all the time every gear i change to it squeeks obviously high gears im goin faster so cant really hear it but i know its there as i like to drive in 5th to save petroll lol im so skint at the mo.
any one ?????
had this same prob about a year ago, and it's coming back again.
it's a lube issue :rolleyes: i friggin forgot where it neede some wd40, as a mate did it for me.
we put it on a stand and i think it was at the spot where the cable goes into the compartment from the bay.
it has a rubber seal around it against moist etc. pullt that thing off and spray the stuff with wd40.
i must say i used other stuff, its a kind of spray on grease.
its in a earosol can, but when it hits it turns into grease.
hope it helps mate!
